Dolphinite no longer here Posted May 18, 2012 Share Posted May 18, 2012 My old (original) plastic toilet leaks water into the bowl after flushing. Its not much of a flow but its enough that the pump cycles on and off every 5 or 6 seconds. Is there a seal somewhere that can be replaced? Do I have to remove the toilet to replace this seal? I think the toilet is a Thetford. It has a side flush handle, not the foot-operated handle and it came stock in my '85 Dolphin 20-footer. John Quote Link to comment Share on other sites More sharing options...
Totem Posted May 18, 2012 Share Posted May 18, 2012 My old (original) plastic toilet leaks water into the bowl after flushing. Its not much of a flow but its enough that the pump cycles on and off every 5 or 6 seconds. Is there a seal somewhere that can be replaced? Do I have to remove the toilet to replace this seal? I think the toilet is a Thetford. It has a side flush handle, not the foot-operated handle and it came stock in my '85 Dolphin 20-footer. John is this the turd cutter seal leaking? Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted May 18, 2012 Author Share Posted May 18, 2012 is this the turd cutter seal leaking? Yup, that's the one and I just found the info on the make. Its not a Thetford, its a Valterra Products toilet. Looks like the ball valve needs replacing. Is this a job for "Joe The Plumber" or can I do it? John Quote Link to comment Share on other sites More sharing options...
Totem Posted May 19, 2012 Share Posted May 19, 2012 Yup, that's the one and I just found the info on the make. Its not a Thetford, its a Valterra Products toilet. Looks like the ball valve needs replacing. Is this a job for "Joe The Plumber" or can I do it? John if you want it to act like its angry at the govt then run for office then sure.. otherwise you can do it... Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 19, 2012 Share Posted May 19, 2012 my thetford leaked water on the floor pulled it and replaced the valve no more leak you can do it. Quote Link to comment Share on other sites More sharing options...
