KC1 Posted April 10 Share Posted April 10 Hello, new owner of this RV. Not sure in the coach I CANNOT get lights when NOT hooked up to shore power. However, the panel does work? Is this a matter of the 12v Converter or disconnection of some wiring? Quote Link to comment Share on other sites More sharing options...
extech Posted April 10 Share Posted April 10 check the coach battery, might be dead or disconnected Quote Link to comment Share on other sites More sharing options...
KC1 Posted April 11 Author Share Posted April 11 (edited) Coach battery is good and connected.. Not sure if I can find anything on YouTube or anyone on this group help me what to look for.. Hoping it's not the 12 v converter.. Edited April 11 by KC1 Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 11 Share Posted April 11 Check your connections on the battery post(s). Also, clean the negative cable connection where it grounds to the frame. A bad ground on the coach battery will cause the same symptoms. Quote Link to comment Share on other sites More sharing options...
KC1 Posted April 18 Author Share Posted April 18 Hey Everyone. I had the Dolphin at an RV repair center. The Tech showed me that it is the converter. Not getting over 11v output of the converter. It's the original converter that is 32 years old. Hopefully the RV repair center will have time for the replacement converter this coming weekend. Quote Link to comment Share on other sites More sharing options...
