Hot Hood
El Rito
What causes the engine to run hot even after a short spin--like a mile or less? I checked recall and it was done in 1999, so not head gasket. Radiator? crossover manifold exhaust?
cheers
first thing comes to mind is a bad thermostat
I will tell you this Toyota does not consider it hot unless it's into the red zone. So you really need to check the coolant temp with an accurate gauge 180-190 is normal.
