Barbara Posted August 6, 2020 Share Posted August 6, 2020 There are patches of caulk all over the roof of my Sunrader. I decided to remove it and and have a look. Each spot revealed a crack of varying size with a black circle drawn around it (permanent marker). Now it has more of a spotted leopard look with all those black circles everywhere. Jeez. The cracks don’t look deep and I am wondering if all that patching is overkill? Isn’t fiberglass pretty darned waterproof, or do I need to reapply caulk? Thanks in advance you for your kindly advice. Quote Link to comment Share on other sites More sharing options...
WME Posted August 7, 2020 Share Posted August 7, 2020 Clean, clean...then seal. https://www.homedepot.com/p/Motsenbockers-16-oz-Spray-Foam-and-Silicone-Caulk-Remover-411-16/202103458 https://www.homedepot.com/s/elastomeric%2520roof%2520coating?NCNI-5 Quote Link to comment Share on other sites More sharing options...
linda s Posted August 7, 2020 Share Posted August 7, 2020 They are not serious. It's just cracked gel coat. You do need to clean them really good but then you can fill them with fiberglass repair or even tub crack filler. You want a product that you can sand with ultra fine sandpaper after it dries. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 7, 2020 Share Posted August 7, 2020 I'd clean the cracks out with a Dremel and fill with gel coat and a fine brush. Quote Link to comment Share on other sites More sharing options...
Barbara Posted August 7, 2020 Author Share Posted August 7, 2020 Thank you so much. Will do! Quote Link to comment Share on other sites More sharing options...
