TreeDogs Toyotas Posted April 15, 2020 Share Posted April 15, 2020 I am hoping to swap a shell from a sunrader onto a 1st gen Tundra. Has anyone on here done it before? I would also like to ask if anyone can give me the length of the sunrader shell where it meets the truck? I wanted to compare the sunrader with the length of the tundra frame. I have thought about axle swapping the tundra to 1 tons to hold the weight of the shell and for legal load capacity. Anyone have an opinion on that and/or if I need to do it or not? Thank you guys! Quote Link to comment Share on other sites More sharing options...
WME Posted April 15, 2020 Share Posted April 15, 2020 Well first thing you need is a giant balance beam scale. Put the Sunrader shell on one end and gold bars on the other. This will give you an idea of cost😵. If you Google Toyota Tundra/sunrader rv there a few pictures. The critical dimensions is the length of the shell from the front of the lower shell to the center of the wheel opening vs the distance from the back of the truck cab to the center of the rear wheel. The one I recall the builder had to cut, splice and lengthen the truck frame to get every thing to match. Good luck Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 15, 2020 Share Posted April 15, 2020 Quote Link to comment Share on other sites More sharing options...
linda s Posted April 16, 2020 Share Posted April 16, 2020 The key measurement to have is the distance from the middle of the rear axle to the cab. I just measured mine and it's 45 inches Linda S Quote Link to comment Share on other sites More sharing options...
TreeDogs Toyotas Posted April 16, 2020 Author Share Posted April 16, 2020 Thank you for the measurement Linda! Haha I am aware of the cost, I am also looking into other models of trucks for a base, as I would like to minimize frame modifications. Did you shorten the wheelbase on that build Derek? Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted April 16, 2020 Share Posted April 16, 2020 I don’t think that’s Derek’s build but here’s another one for your consideration! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 16, 2020 Share Posted April 16, 2020 No, that's not mine. Just a picture I saved off the 'net. This might be helpful. For the 1989-1993 112" V6 C&C. I know that earlier (don't know which years) SWB chassis/trucks were 110" WB and the cab dimensions were a bit smaller. This is the 1983 C&C. Quote Link to comment Share on other sites More sharing options...
WME Posted April 16, 2020 Share Posted April 16, 2020 So Derek ya got a set of those line drawings for a 2002 Tundra? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 16, 2020 Share Posted April 16, 2020 That would be too easy. Quote Link to comment Share on other sites More sharing options...
