jhdbad Posted December 30, 2018 Share Posted December 30, 2018 I have a dometic RM2401 fridge in my Sunrader and the latch is not working ... any sources for a replacement of the original? I looked on internet but couldn’t find an orginal thanks John Quote Link to comment Share on other sites More sharing options...
linda s Posted December 30, 2018 Share Posted December 30, 2018 I know lots of people have just installed a hook latch on the outside to keep it closed but this one looks pretty close to the real thing. Not sure but it's dark and cold outside and I really don't want to take my door apart anyway to find out. http://www.dyersonline.com/dometic-refrigerator-gray-travel-slider-angled-door-lock-complete.html Linda S There are other locks on this site. Just look for Dometic refrigerator parts then hardware. Outside latches used on the newer models might be able to be added and not look too bad either. http://www.dyersonline.com/dometic Quote Link to comment Share on other sites More sharing options...
WME Posted December 30, 2018 Share Posted December 30, 2018 Not OEM but the will work, cheap too. https://www.amazon.com/Dreambaby-Premium-Appliance-Fridge-Latch/dp/B01NCONVE4/ref=pd_lpo_vtph_263_lp_t_2/142-7411594-1375020?_encoding=UTF8&psc=1&refRID=D7DHZT0AN7ZRQR2KXVT3 Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted January 3, 2019 Share Posted January 3, 2019 http://www.adventurerv.net/dometic-refrigerator-replacement-refer-door-handle-rm2611-p-16247.html if you google the part numbers you will find it elsewhere too. the part number I have is 2931600023. HINT - do NOT use that latch to PULL the door open. Latch will last longer, also when closing push in bottom of door. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted January 3, 2019 Share Posted January 3, 2019 here is the parts list. Dometic_Refrig_RM2410_PartsList.pdf Quote Link to comment Share on other sites More sharing options...
