Juano Posted December 21, 2018 Share Posted December 21, 2018 (edited) Hi, I'm looking for some Bilstein shocks for my 84' 4wd Sunrader with the upgraded 1 ton axle. I called Bilstein and they told me that they don't have anything for motorhomes, so apparently they are not really experts in the topic as I've seen a PDF catalog with motorhome area. in this PDF says that for a Toyota mini motorhome 2wd parts needed are: 24-184830 (front) | 24-002585 (rear). It doesn't mention anything about 4wd, so I went to Blistein's website and typing 84' 4wd Pickup I get: 24-184601 (front) | 24-011402 (rear). Any help will be really appreciated as I need to order them NOW! Thanks! Edited December 21, 2018 by Juano Quote Link to comment Share on other sites More sharing options...
WME Posted December 21, 2018 Share Posted December 21, 2018 If all else fails remove the old shocks and measure the extended/collapsed length The Bilstein catalog should have the info to compare with Also check the ends are correct. Quote Link to comment Share on other sites More sharing options...
linda s Posted December 21, 2018 Share Posted December 21, 2018 You need the regular 4x4 shocks. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 21, 2018 Share Posted December 21, 2018 Before ordering, check your old ones. I wouldn't want to bet either way what might be there with a FF rear axle installed. Bilstein 24-002585 4600 shock. (2WD) Bilstein (24-002585) 4600 Series shock absorber Collapsed length (inches): 14.1 Extended length (inches): 22.3 Travel (inches): 8.2 Upper mount: Eye 16mm Lower mount: Eye 16mm This part replaces Bilstein F4-B46-0258-H1. Bilstein 24-011402 4600 shock. (4x4) Bilstein (24-011402) 4600 Series shock absorber Collapsed length (inches): 13.6 Extended length (inches): 20.9 Travel (inches): 7.3 Upper mount: Eye 19mm Lower mount: Eye 19mm This part replaces Bilstein F4-B46-1140-H2. https://www.my4by.com/bilstein-24-002585-shock.html https://www.my4by.com/bilstein-24-011402-shock.html Quote Link to comment Share on other sites More sharing options...
Juano Posted December 23, 2018 Author Share Posted December 23, 2018 Thanks everybody! I ended buying 4wd front 24-184601 and 1 ton rear 24-002585. Hope they works! Quote Link to comment Share on other sites More sharing options...
