Warrior97405 Posted April 22, 2018 Share Posted April 22, 2018 Has anyone ever replaced the igniter? What is the part name, are there any online retailers that carry the part, know of any manuals or tutorials for replacing it? Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted April 27, 2018 Share Posted April 27, 2018 might want to do some more troubleshooting. If it is clicking the igniter is probably working. have you removed the cover and looked in the sight glass to see if a spark is visible? what you are describing sounds more like a "no gas" scenario - verify heater gas shut off is on? low dc voltage will cause problems too. Quote Link to comment Share on other sites More sharing options...
Osider Posted January 2, 2019 Share Posted January 2, 2019 Late replay, new member. I have this happen all the time when I am not on gas for a while. If it sits a while you need to purge/ flush the system. With my fridge and heater as well I light my stove burners first to purge the gas lines. then my heater and fridge will catch. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted January 8, 2019 Share Posted January 8, 2019 had this problem a while back. found out my rv battery was too old and weak spin the blower fast enough to allow the heater to ignite. new battery and worked great . Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 9, 2019 Share Posted January 9, 2019 19 hours ago, 5Toyota said: had this problem a while back. found out my rv battery was too old and weak spin the blower fast enough to allow the heater to ignite. new battery and worked great . The sail switch and the over temp are the first lines of defence if there is not enough wind the gas valve will not open. The problems with the OEM boards they don't care and it will just blow cold air on your feet until you get up and turn it off. The new boards will at least try 3 times. . Quote Link to comment Share on other sites More sharing options...
5Toyota Posted January 12, 2019 Share Posted January 12, 2019 thank you and yes had that happen one time was out of propane . but had a nother tank .nice to know if I ever need another board Quote Link to comment Share on other sites More sharing options...
