AbleThought Posted October 7, 2017 Share Posted October 7, 2017 Hey all, my shifter is tough to get in gear on cold start ups. I’m guessing that the transmission fluid needs replacing as I’ve never done it. Think that’s the case? What is your recommendation on transmission fluid for an 83 Sunrader? thanks! Quote Link to comment Share on other sites More sharing options...
Bob C Posted October 7, 2017 Share Posted October 7, 2017 I believe that you need to lubricate the connections through-out the shifting system. Spray some lube onto every connection from the steering column all the way to the transmission. I think that you have some rust or buildup on these joints and it loosens up after being moved a bit. Try unlocking the steering column and moving the shifter through all of the gear positions a couple of times to see if it gets easier after a couple times. One of my vehicles that sat for weeks without being used developed the same problem and it was resolved by lubrication. Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 7, 2017 Share Posted October 7, 2017 Stick or automatic? Quote Link to comment Share on other sites More sharing options...
AbleThought Posted October 9, 2017 Author Share Posted October 9, 2017 On 10/7/2017 at 9:40 AM, Bob C said: I believe that you need to lubricate the connections through-out the shifting system. Spray some lube onto every connection from the steering column all the way to the transmission. I think that you have some rust or buildup on these joints and it loosens up after being moved a bit. Try unlocking the steering column and moving the shifter through all of the gear positions a couple of times to see if it gets easier after a couple times. One of my vehicles that sat for weeks without being used developed the same problem and it was resolved by lubrication. Good idea I’ll do that Quote Link to comment Share on other sites More sharing options...
AbleThought Posted October 9, 2017 Author Share Posted October 9, 2017 On 10/7/2017 at 10:42 AM, Maineah said: Stick or automatic? Stick sorry I forgot to mention. Quote Link to comment Share on other sites More sharing options...
WME Posted October 9, 2017 Share Posted October 9, 2017 With a stick transmission the fault list looks sortta like this. 1. Low fluid in clutch master cylinder. 2, Bad master or slave cylinder. 3. Its just wore out. 4 The shifter ball is worn. Replace socket and seat https://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-sockets 5. Bad throw out bearing. 6. Bad fluid is way down the list. It should be 80-90w Quote Link to comment Share on other sites More sharing options...
5Toyota Posted January 8, 2018 Share Posted January 8, 2018 shifter is tuff to get in gear whin cold on a stick shift . how cold are you talking at 20 below 0 I have had to use both hands to shove a 5 speed Toyota or a 4 speed Datsun in too low gear . gear oil can get some what thick at very low temps. Quote Link to comment Share on other sites More sharing options...
