"DAM" nice Chinook
wonderabout
thanks derek, ok just trying to educate myself here. why no dually ? because it is a "chinook" ?, i was under the impression all toya's had 4 wheels in rear. either a dually set up,  or a tandem configuration. thanks for your knowledge in advance. joe from dover
'Foolies' are dual wheels welded or bolted together to look of real 'dualies' and are what lead to overloaded axles/bearings on a 5-lug axle. They're what lead to rear axle failures and the axle recall. See below for a snapped axle on an 18' Sunrader with foolies.
A 'tag' axle is an extra axle added behind the standard rear axle. That I've seen, an experiment tried by a few manufacturers from '79-'81 and then dropped. See the '79 Dolphin 300 version of the tag axle (attached below).
1979 Dolphin 300 Micro Mini.pdf
