Got Toyota Posted October 5, 2016 Share Posted October 5, 2016 Hello, I have an escape hatch on my 87 odyssey measuring 15 1/2 x22 1/2id on old one I removed .I can't easily find the right sized one online. I find them 15X22 but there's going to leave a pretty big gap. I would really appreciate it if someone that replaced there's semi recently and could kinda steer me to the right one.... Quote Link to comment Share on other sites More sharing options...
linda s Posted October 5, 2016 Share Posted October 5, 2016 You need to know the cut out size. Look here, a 15x22 escape hatch has a cut out much bigger than the hatch size. http://tweetys.com/heng-s-escape-hatch-15-x-22.aspx?gclid=CL-DzteBw88CFQEQaQodCSEEzA Linda S Quote Link to comment Share on other sites More sharing options...
Got Toyota Posted October 5, 2016 Author Share Posted October 5, 2016 7 hours ago, linda s said: You need to know the cut out size. Look here, a 15x22 escape hatch has a cut out much bigger than the hatch size. http://tweetys.com/heng-s-escape-hatch-15-x-22.aspx?gclid=CL-DzteBw88CFQEQaQodCSEEzA Linda S Thank you for the great info, I saw this one when I was looking but was uneasy about getting the wrong size and really don't want to have to send it back or worse and have to cut a larger hole. Quote Link to comment Share on other sites More sharing options...
Got Toyota Posted November 6, 2016 Author Share Posted November 6, 2016 Well , bought the 15x22 and its about 1.5 inches larger than my hole all the way around,kinda scared cutting into my rooftop but I guess its the closest I can get, any suggestions on cutting into my rooftop? Quote Link to comment Share on other sites More sharing options...
linda s Posted November 7, 2016 Share Posted November 7, 2016 Before you start cutting please give me our exact cut out size and let me see if I can find a better fit. Linda S Quote Link to comment Share on other sites More sharing options...
Got Toyota Posted November 7, 2016 Author Share Posted November 7, 2016 It's 22 3/4 / 15 5/8 could probably squeeze 15 3/4 but very tight. Thanks for helping me out. Nothing I've looked at online has the inside dimensions. Quote Link to comment Share on other sites More sharing options...
linda s Posted November 7, 2016 Share Posted November 7, 2016 OK cutting it is. Mark carefully the opening needed. I would cut from the roof not inside. Drill holes just inside corners so you can get jig saw in to cut straight lines of opening. Clean corners out after. If edges of paneling inside aren't perfect the garnish will cover some of that. Piece of plywood on roof will help to distribute your weight up there. Good luck. Your old one is probably a Ventline escape hatch and they don't make them anymore. Linda S Quote Link to comment Share on other sites More sharing options...
Got Toyota Posted November 7, 2016 Author Share Posted November 7, 2016 I appreciate at your help, tried updoading a picture of the old one and it kept saying the same error. Oh well at least now I'll have a hole compatible if it needs replacing in the near future. Thanks again. Quote Link to comment Share on other sites More sharing options...
linda s Posted November 7, 2016 Share Posted November 7, 2016 Wish I could have done more. There was a time not that long ago when I could track down older parts. Guess they are all gone by now Linda S Quote Link to comment Share on other sites More sharing options...
