85Diesel Posted June 17, 2016 Share Posted June 17, 2016 Quick question, and I'm sure it's been answered here before, but are Chinooks built on long bed or short bed trucks? Quote Link to comment Share on other sites More sharing options...
zero Posted June 17, 2016 Share Posted June 17, 2016 Chinook is built on a 110.25" wheelbase. Quote Link to comment Share on other sites More sharing options...
zero Posted June 17, 2016 Share Posted June 17, 2016 I'll add the Chinook is on a 110.25" wheelbase and there was no option. That is a little shorter then a short-bed truck built in later years. E.g., "short" 1988 has a 112" wheelbase and a "long" has a 137" wheelbase. Quote Link to comment Share on other sites More sharing options...
85Diesel Posted June 18, 2016 Author Share Posted June 18, 2016 So sounds like a chinook camper wouldn't line up with a single cab longbed 85 4x4. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 18, 2016 Share Posted June 18, 2016 They come very close. My friend Randy has one on an 87 4x4 and it matches up very well. Linda S Quote Link to comment Share on other sites More sharing options...
zero Posted June 18, 2016 Share Posted June 18, 2016 7 hours ago, 85Diesel said: So sounds like a chinook camper wouldn't line up with a single cab longbed 85 4x4. Get the tape-measure out. Wheelbase is NOT the measurement a person needs. Has little to do with the coach fitting or not. You need the distance from the back of the truck cab to the center-line of the rear-axle. A Toyota Chinook measures 48.7" from the back of the cab to the center-line of the rear wheels. A 1985 112" wheelbase Toyota truck measures 43.9" to the rear center-line of the rear-axle. Even though the frame is 2" longer, the cab is also longer, so less room for a coach in back. I'm sure you can make anything fit with work. One perfect fit for a Chinook body on a later truck is a 2003 Chevy S10 standard-cab, long-bed. Measures 47.5" from the back of the cab to the center-line of the rear axle. Quote Link to comment Share on other sites More sharing options...
zero Posted June 18, 2016 Share Posted June 18, 2016 Here's a diagram of the later Chinook coach like used 1975-1979. 1973-1974 models I have no specs on and they might of been slightly different and/or shorter. The Toyota truck chassis went through big changes that came out for model year 1975. Also - the Toyota Chinook does not have the rear wheels perfectly centered in the rear wheel wells. Quote Link to comment Share on other sites More sharing options...
