davidtan Posted September 12, 2015 Share Posted September 12, 2015 So , the results are in. Installed the Atwood Command air 13.5 (they sent me 4 units - 2 broken in shipping , 1 actually working unit , and another by mistake . Wherever they are shipping out from needs to package them better. The boxes show up all ripped and banged up). I borrowed a Yamaha MZ80 2000 watt generator from a friend and tried starting it up. NO GO. The generator just kept dying whenever the compressor kicked in. So that sucked. I called a Honda generator store to see if I could test the RV ac right there in their store and said it was OK, but they said it was too small too for a 13.5 ac unit. I got to the Honda store and we plugged it in . The Atwood is kinda weird because it runs for around 3 minutes on fan only to cool down all the hear exchangers before the compressor kicks in. Then the compressor kicked in and walla , the Honda kept going. Upon reading the specs, the Honda has a 98 cc engine while the Yamaha had a 79 cc engine . Both rated at 2000 surge watts , 1600 running , but I guess the Honda has more torque to keep going on the surge. Mystery put to rest, a Honda EU2000i will start a Atwood 13.5 command air. I even tried turning on the fridge and it did not even bog. Good times ps.. 85 lbs for AC , 45 lbs for genset. Not bad Quote Link to comment Share on other sites More sharing options...
zero Posted September 12, 2015 Share Posted September 12, 2015 The test won't be of much use until you are actually out using the AC for a day or so and it keeps on working without tripping the breaker on the generator. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 23, 2016 Share Posted June 23, 2016 On 9/12/2015 at 1:03 PM, davidtan said: So , the results are in. Installed the Atwood Command air 13.5 (they sent me 4 units - 2 broken in shipping , 1 actually working unit , and another by mistake . Wherever they are shipping out from needs to package them better. The boxes show up all ripped and banged up). I borrowed a Yamaha MZ80 2000 watt generator from a friend and tried starting it up. NO GO. The generator just kept dying whenever the compressor kicked in. So that sucked. I called a Honda generator store to see if I could test the RV ac right there in their store and said it was OK, but they said it was too small too for a 13.5 ac unit. I got to the Honda store and we plugged it in . The Atwood is kinda weird because it runs for around 3 minutes on fan only to cool down all the hear exchangers before the compressor kicks in. Then the compressor kicked in and walla , the Honda kept going. Upon reading the specs, the Honda has a 98 cc engine while the Yamaha had a 79 cc engine . Both rated at 2000 surge watts , 1600 running , but I guess the Honda has more torque to keep going on the surge. Mystery put to rest, a Honda EU2000i will start a Atwood 13.5 command air. I even tried turning on the fridge and it did not even bog. Good times ps.. 85 lbs for AC , 45 lbs for genset. Not bad I'm interested in how the Atwood is working out for you on the mighty little Honda, what is your outside temperature and elevation? Sent you a PM on this also in case you miss this. Jim Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 23, 2016 Share Posted June 23, 2016 My 2000 will start & run my 13.5 btu ac. It grunts and the overload light lights up for a bit. (at sea level). I have run it for 30 minutes then I give it a break. By my math, the AC needs all 2000 watts (spec-ed draw at 19.something amps) and since the specs are for 2000 watts for 30 minutes followed by 1600 watts I do not push it any farther. my gen is at about 1200 hours (measured by the amount of fuel consumed. The unit has a flashing light that will reports 100 hour intervals up to 500 hours. I measured fuel usage to hours run and I think the specs are pretty close - about 8 hours for 1 gallon) really should have at least a 2.5k watt gen to run this ac. I rarely run my AC this way - a few times I really wanted to cool down the camper though. Quote Link to comment Share on other sites More sharing options...
Totem Posted June 23, 2016 Share Posted June 23, 2016 Thanks for the truth! Quote Link to comment Share on other sites More sharing options...
