mustrmrk Posted September 4, 2015 Share Posted September 4, 2015 I just replaced my worn out fan clutch and in the process managed to tear up my old, brittle, cracked fan shroud. In searching for a replacement, I haven't been able to find one for a 1987 w/ an automatic transmission. Most of the ones on ebay say "manual transmission only. Does anyone know if there really is a difference? And, if so, do you perhaps have a source for the correct one for the automatic? Quote Link to comment Share on other sites More sharing options...
linda s Posted September 4, 2015 Share Posted September 4, 2015 Was it a 2 piece shroud? If so this might be the bottom half. Your local Toyota dealer can tell you if part number 3 is also available. Not too expensive, get the real thing http://trdtoyotaparts.elmoretoyota.com/oe-toyota/1671254050 Linda S Quote Link to comment Share on other sites More sharing options...
mustrmrk Posted September 4, 2015 Author Share Posted September 4, 2015 Thanks, Linda. After a bit more looking around, I found this: http://toyotaparts.lagrangetoyota.com/p/Toyota_1987_4Runner-2400CC-EFI--AUTOMATIC--4-SPEED-COLUMN-SHIFT-LOW-DECK-PICKUP--DELUXE/SHROUD-SUB-ASSEMBLY--FAN/42965046/1671135030.html Looks like the correct part for the upper shroud for a 1-ton automatic w/ towing package. Quote Link to comment Share on other sites More sharing options...
mustrmrk Posted September 5, 2015 Author Share Posted September 5, 2015 Update - I found the part number on the shroud - it's the same one everyone's selling for manual transmission only - 1671135020 - so I just went ahead and ordered it. Quote Link to comment Share on other sites More sharing options...
