Pammy Posted July 25, 2015 Share Posted July 25, 2015 I was testing a/c and fridge was on and suddenly I lost electricity to coach. I did have power from battery for lights so I went ahead to my overnight. Now I'm not even getting battery power to the lights. Can anyone point me to a fuse or other possible issue? I have guests coming in a few minutes. Quote Link to comment Share on other sites More sharing options...
WME Posted July 25, 2015 Share Posted July 25, 2015 Check your 110 v AC source, plug in light bulb. Your RV has a power panel that normally has 2 110v circuit breakers and 6+ 12v fuses Quote Link to comment Share on other sites More sharing options...
jjrbus Posted July 25, 2015 Share Posted July 25, 2015 There should be a electric panel in your unit somewhere, mine is brown. The first thing I would check is if a breaker is tripped. Then I would head outside and see if the breaker is tripped where you are plugged in or if the plug is loose. Jim Quote Link to comment Share on other sites More sharing options...
Pammy Posted July 25, 2015 Author Share Posted July 25, 2015 Any idea where it might be I haven't come across it yet. Mine is a Winn warrior Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 25, 2015 Share Posted July 25, 2015 Check down at floor level, under the couch near the kitchen sink. Quote Link to comment Share on other sites More sharing options...
Pammy Posted July 25, 2015 Author Share Posted July 25, 2015 Check down at floor level, under the couch near the kitchen sink. Ok guys I found it. I flipped the breaker on and off and checked all fuses and still nothing. Quote Link to comment Share on other sites More sharing options...
Back East Don Posted July 25, 2015 Share Posted July 25, 2015 Ok guys I found it. I flipped the breaker on and off and checked awl fuses and still nothing. What are you plugged into? Perhaps the breaker or ground fault tripped at the source and not the RV. Check the plug the RV is plugged into. Quote Link to comment Share on other sites More sharing options...
