All Electric Suddenly Gone On Maiden Voyage!
I was testing a/c and fridge was on and suddenly I lost electricity to coach. I did have power from battery for lights so I went ahead to my overnight. Now I'm not even getting battery power to the lights. Can anyone point me to a fuse or other possible issue? I have guests coming in a few minutes.
Check your 110 v AC source, plug in light bulb.
Your RV has a power panel that normally has 2 110v circuit breakers and 6+ 12v fuses
There should be a electric panel in your unit somewhere, mine is brown. The first thing I would check is if a breaker is tripped. Then I would head outside and see if the breaker is tripped where you are plugged in or if the plug is loose. Jim
Ok guys I found it. I flipped the breaker on and off and checked awl fuses and still nothing.
What are you plugged into? Perhaps the breaker or ground fault tripped at the source and not the RV. Check the plug the RV is plugged into.
