jjrbus Posted July 9, 2015 Share Posted July 9, 2015 93 Toyota V6, Should the tensioner/idler pulley for the Ac compressor move without loosening the nut on the pulley? Not sure if mine is stuck or that is the way it should be ?? Jim Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted July 9, 2015 Share Posted July 9, 2015 Should be a bolt through the pulley and a bolt on the adjuster, which is behind the pulley. If they're both snug, nothing should be moving. (These tend to rust and break easily when old, so shoot em with some PB Blaster before you start wrenching.) Quote Link to comment Share on other sites More sharing options...
jjrbus Posted July 9, 2015 Author Share Posted July 9, 2015 Thanks for the response. Does the bolt through the pulley have to be loose in order to use the adjuster?? Jim SW FL Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted July 9, 2015 Share Posted July 9, 2015 Yes, it does. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted July 11, 2015 Share Posted July 11, 2015 loosen the thru nut as Ctgriffi says, then the bolt that you can reach from the bottom will turn Quote Link to comment Share on other sites More sharing options...
