guyg Posted June 23, 2015 Share Posted June 23, 2015 (edited) I've found this 1989 22 ft Odyssey Americana for sale in my area. Six cyl with 75k miles. Any thoughts certainly welcome. They're asking $5k. Reasonable? Thanks in advance for your input. I've always been happy with our Toyota cars and pickups and hope the same would extend to the camper products. (Edited: should have said 75k not 7k). Edited June 23, 2015 by guyg Quote Link to comment Share on other sites More sharing options...
zero Posted June 23, 2015 Share Posted June 23, 2015 Sounds like a good price. I'm sure you know that Toyota's reputation has little to do with an RV body stuck on the back unless it's a Toyota-sponsored RV like a 70s Chinook. How does that V6 have only 7K miles? That's the only part of the story that would make me nervous unless you know, 100% for sure, what was replaced. That is unless the entire RV only has 7K miles. I see a lot of engines being called "rebuilt" or "new" that are not either. Quote Link to comment Share on other sites More sharing options...
guyg Posted June 23, 2015 Author Share Posted June 23, 2015 Sorry jdemaris, mistyped the mileage. 75k. I do understand the RV body not being a Toyota. Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted June 23, 2015 Share Posted June 23, 2015 Others here will have more/better suggestions, but here's where I'd start... Make sure it's got the full-floating 1-ton axle on the rear. Check the tires: tread condition and date (10 years+ is considered risky). New rubber could run you 6-8 bills. Did you mean 70K on the mileage? Make sure it's had the timing belt replaced. V6 had head gasket problems. Verify with paperwork and/or dealer that this service was done. Leaks are frequently a problem on older rigs. Check the ceiling for evidence and walk around on the roof some; it shouldn't feel like it's going to cave in on you. Hard to tell much from one exterior photo, but if the interior isn't trashed, and it drives/brakes well... then, yeah $5K is probably a good price. Quote Link to comment Share on other sites More sharing options...
guyg Posted June 23, 2015 Author Share Posted June 23, 2015 Thanks, ctgriffi. Good info. None of the interior pix shows the roof line, so really can't tell without seeing it. Plan to do that in a couple of days. And thanks for the tip on head gasket issue. Knew about the timing belt. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 23, 2015 Share Posted June 23, 2015 Well it's not an Americana. It is an Odyssey but wrong model. 5000 is a good price for this if everything works well Linda S Looking at the ad now. Front windows have been covered so may have been some water damage there in the past but repair looks very well done. Inside looks faded but clean. That rose color didn't age well. The biggy here is this baby is the 5 speed. Super hard to find. Buy this thing Quote Link to comment Share on other sites More sharing options...
guyg Posted June 24, 2015 Author Share Posted June 24, 2015 It got away. He sold it two days ago. Thanks to all of you for your input. I'll be back. Quote Link to comment Share on other sites More sharing options...
