jjrbus Posted June 8, 2015 Share Posted June 8, 2015 I ordered a replacement radiator, took it out of the box to compare it for fit. It has aluminum core and plastic tanks. It appears to be a good fit compared to the old one. Sunbelt SBR 1190 But it appears to be a single core radiator. the core being very thin approximately 1 1/2" Is this OK for my 93 V6 auto?? Jim Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 8, 2015 Share Posted June 8, 2015 Their website describes the SBR-1190 as being "3 ROW". http://sunbeltradiators.com/rlookup/partlist/Toyota/Pickup/1992/3.0L/Radiator Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 8, 2015 Author Share Posted June 8, 2015 Thanks for the quick response!! When I look into the radiator I only see 1 row? Left click on photo for larger image Hard to get a good picture, maybe this is the new math or its a 3 row rated?? Jim SW FL Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 8, 2015 Share Posted June 8, 2015 Good luck with it. http://reviews.birdeye.com/sunbelt-radiators-inc-835447680 I've never heard of Sunbelt. I know that Spectra Premium is sold by many outlets as well as to OEM. http://www.amazon.com/Spectra-Premium-CU945-Complete-Radiator/dp/B000C7S5K8/ref=pd_sim_sbs_263_3?ie=UTF8&refRID=1SC403ZD4EHZWBEDXVJD Quote Link to comment Share on other sites More sharing options...
WME Posted June 9, 2015 Share Posted June 9, 2015 Aluminum is stronger than brass, so they can make the tubes wider. So maybe 3 row rated isn't to far off. Normal brass tubes are around 1/2" wide. Look through the fins with a light and see how wide the tubes are. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 9, 2015 Author Share Posted June 9, 2015 Thanks for the responses. I did some reading and looking at both radiators the aluminum has as much if not more cooling surface then the factory one. I do find the 3 core description to be deceptive. Thanks Jim SW FL Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 9, 2015 Share Posted June 9, 2015 Can't say I've ever come across the term '3 row rated' before. Quote Link to comment Share on other sites More sharing options...
