kayakthecoast Posted April 11, 2015 Share Posted April 11, 2015 This rear axle off an 1987 extended cab 4x4 Sunrader (not mine) does not seem to have the 6 inner lug bolts and end nuts on the inside axle? Is this a full floater? See pic Quote Link to comment Share on other sites More sharing options...
linda s Posted April 11, 2015 Share Posted April 11, 2015 No it's not a full floater. If it's the ad in Portland they have pics of the undercarriage. Look at the inside wheel. the brake adjustment area on a true dually would be depressed into the wheel. On this one the inside of the wheel is flat which means it's a fooley not a dually Linda S Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted April 11, 2015 Author Share Posted April 11, 2015 That's what I thought. I'm in contact with the new owner and we are comparing rigs! Same year and engine. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 12, 2015 Share Posted April 12, 2015 Pretty sure the guy that sold it compared rigs with my friend Jerry when he first bought it. Jerry had a 4x4 Sunrader too but with the front range full float conversion and single wheels in the back. 16 inch E load range tires. It was a bear. Linda S Quote Link to comment Share on other sites More sharing options...
zero Posted April 12, 2015 Share Posted April 12, 2015 This rear axle off an 1987 extended cab 4x4 Sunrader (not mine) does not seem to have the 6 inner lug bolts and end nuts on the inside axle? Is this a full floater? See pic There is not enough info in that photo to determine what it is. For sure it is not an original Toyota/Dyna full-floating dually. That does not rule out some sort of full-float conversion with an added dual-wheel adapter. All it takes is a spindle/hub-extension, two bearings, and a custom-made axle to fit. If that ring of inner bolts are holding in the end of an axle flange, then yes it IS a full-floater. Can't tell with just the one photo. Any axle-assembly that has non-weight bearing axles is full-floating. So called "fake duallies" are usually just cast-iron or aluminum adapters that stick way out and allow a second wheel to be bolted on. That picture could be showing a mixture of both - but again, not enough info. Just looking at the one photo, if kind of looks like a cast-iron Arrowcraft wheel-extension with a second wheel just bolted to it. Quote Link to comment Share on other sites More sharing options...
linda s Posted April 12, 2015 Share Posted April 12, 2015 I recognized Jason's description as a 4x4 that was on craigslist in Portland and the original ad had more pictures. It was the standard set-up that Sunrader put on their 4x4's and appeared to be un-altered with original wheels. I've seen enough of them to know what it is Linda S Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted April 12, 2015 Author Share Posted April 12, 2015 I'll pass this info along, thanks. Quote Link to comment Share on other sites More sharing options...
