85mirage Posted March 26, 2014 Share Posted March 26, 2014 My Shasta's manifold is cracked near bolt. Its not too loud but its time.I need new one.This ebay part should work with my 86 rv. Can I unblock and install o2 . Any thoughts? Emissions? I'm not in CA cheap http://www.ebay.com/itm/NEW-TOYOTA-4-RUNNER-22REC-EXHAUST-MANIFOLD-88-95-/140350735790?pt=Motors_Car_Truck_Parts_Accessories&hash=item20ad8e45ae&vxp=mtr Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 26, 2014 Share Posted March 26, 2014 Can't be welded? The older ones used to crack in the middle I have welded dozens. Just be sure your exhaust pipe port is the same. I don't see any reason why the O2 sensor would not work if it fits I would add studs and nuts instead of bolts. The manifold does look like some thing from China. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted March 27, 2014 Share Posted March 27, 2014 The manifold you posted looks pretty exact to the manifold I just put on my truck. You can order a manifold kit from advance auto parts website. It comes with manifold and all gaskets. You have to order it online and enter the code TRT30 for 30% off which brought the manifold with the gaskets to around $60 I believe I paid. The manifold worked but was of not so great quality. I had to shave a few parts of the metal off from casting for bolts to clear. My O2 sensor hooked right up. Quote Link to comment Share on other sites More sharing options...
