darrel Posted March 16, 2014 Share Posted March 16, 2014 Completed this upgrade yesterday. Installed Bargman #47-84-005 LED. Couldn't get the turn signal to work properly hyper-flash. Tried a led compatible flasher from AutoZone but it didn't work with led or incandescent bulbs. Then tried another flasher and works perfectly. I have included pictures. The EP34 works, normal flash. But it is longer and doesn't have the Toyota mounting tab. I taped it together and zip tied it securely. Turns out the negative-positive terminasl are reversed. AutoZone cross reference is wrong. Quote Link to comment Share on other sites More sharing options...
Roy in Jax Posted March 16, 2014 Share Posted March 16, 2014 Thanks for the idea, having the same problem with my new led lights. Quote Link to comment Share on other sites More sharing options...
kayakthecoast Posted April 6, 2014 Share Posted April 6, 2014 This is on my list of improvements, thanks for working out the flasher issue for us. Quote Link to comment Share on other sites More sharing options...
turtle Posted April 12, 2014 Share Posted April 12, 2014 I went one step further. I use the center of the triple as the yellow turn AND BOTH the inside and outside as running and brake/stop lights I welded on some trailer 4x4 box light holders with rear and side facing light cutouts onto the pop-shoot holder and put some diamond plate over the larger area. MUCH brighter in the rear with dual running and dual brake lights AND the backup lights are about as bright as the headlights now Quote Link to comment Share on other sites More sharing options...
darrel Posted April 12, 2014 Author Share Posted April 12, 2014 I like both of your mods. Quote Link to comment Share on other sites More sharing options...
rigger camper Posted April 12, 2014 Share Posted April 12, 2014 I'm looking into led tail lights as well. I had just assumed that I would put a resistor in line to slow the flash rate. That is what I did on my bike and it worked perfectly. Anyone do it this way? Quote Link to comment Share on other sites More sharing options...
darrel Posted April 12, 2014 Author Share Posted April 12, 2014 I installed led cluster brake tail a while back. Chose not to go with the resistor because they get hot. If you look at my setup everything around the tail light is plastic. Didn't want to melt anything. Used a led compatible flasher. It works perfectly. Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 12, 2014 Share Posted April 12, 2014 I agree with the proper flasher if you add a resistor your back to the current draw of a standard bulb. Quote Link to comment Share on other sites More sharing options...
turtle Posted April 12, 2014 Share Posted April 12, 2014 Get the proper flasher unit for LED lights. Quote Link to comment Share on other sites More sharing options...
rigger camper Posted April 12, 2014 Share Posted April 12, 2014 Thanks for the responses. On my bike you can't change the flasher but what you say makes sense for the Dolphin. Quote Link to comment Share on other sites More sharing options...
turtle Posted April 12, 2014 Share Posted April 12, 2014 I like both of your mods. Using dual running/brake lights is simple. Just add a jumper from the outside (original) brake/park light to the inside where the old backup light was. Then both inside and outside lights are park/brake. I did this same mod on my old 1981 diesel toyota RV which had surface mount reflect-o-lite 1400 tripples that I had to rebuild. Worked great on those. Worked great on the newer Bargman lights I didn't do the weld on trailer lights as I did not think of doing that at the time. Wish I had instead of using a 55 watt quarts driving light as a backup light Page about the reflect-o-lite rebuild and mod: http://www.toymike.com/diesel/pics/Rear_Lights/ Quote Link to comment Share on other sites More sharing options...
