MontanaChinook Posted December 15, 2013 Share Posted December 15, 2013 This is where the 12V connects to the fridge. Does this look like I can just stick bare wire in there and then screw down on the wire, or is there some special kind of connector that goes in here? Quote Link to comment Share on other sites More sharing options...
linda s Posted December 15, 2013 Share Posted December 15, 2013 Do the wires connected by the manufacturer there have little u shaped brackets or is it just wire. Do it the same way they did. Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 15, 2013 Share Posted December 15, 2013 Yes you can that is a European barrier strip slowly making their way into American wiring. A little heads up I see a brown wire, in Europe (Domedic) that is usually a ground wire (earth). Just check it with your ohm meter to the case. Quote Link to comment Share on other sites More sharing options...
Roy in Jax Posted December 15, 2013 Share Posted December 15, 2013 Tell us more about your new 12v Fridge. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted December 15, 2013 Author Share Posted December 15, 2013 I didn't want to pull any wires out...forward progress only! But I'll check them out. The manual, surprisingly enough, says polarity does not matter. What would you like to know about the fridge? It's a Dometic, 3-way, 1.9 cubic feet. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted December 17, 2013 Author Share Posted December 17, 2013 That's what I like to hear! Things are starting to really come together... Quote Link to comment Share on other sites More sharing options...
