MontanaChinook Posted December 14, 2013 Share Posted December 14, 2013 I bought some stock sheet metal from Home Depot to cover over the side of the cabinets that are right inside my door. It's a high traffic area, and is definitely going to get banged up. So I'm putting a small sheet of metal over that area. I bought some heavy-duty adhesive. Just curious if people think the adhesive will be enough, or if I will need to put a few screws through it. I'd rather just use the adhesive, but...of course what I most want is for it to stick, and stay. It's just a stock sheet metal piece, not sure how thick...but it was right in an aisle in the hardware store, pre-cut and priced. Pretty thin. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted December 15, 2013 Share Posted December 15, 2013 Zach, I don't know what you got for metal but Liquid Nails does a pretty goot job sticking anything to most anything. I would wipe down the side of the metal that will be getting the glue with acetone to remove any old oil or crud that might be there from the manufacturer. Do a dry fit with the metal with all of your props or clamps nearby. Liquid Nails begins to set up quickly right out of the tube. John Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted December 15, 2013 Author Share Posted December 15, 2013 Thanks John. I bought Loctite construction adhesive. Hopefully that works as well? I'll clean the metal off. And hopefully with the warm weather this weekend, and an electric heater running inside the camper, it'll be warm enough for it to set up well... Quote Link to comment Share on other sites More sharing options...
linda s Posted December 15, 2013 Share Posted December 15, 2013 I used Loctite 8X,the super strong stuff, to glue the siding back in place on my Tiger motorhome. It's never coming loose again. Even sanded down smoothly so I can repaint that area. Don't bother with screws Linda S Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted December 15, 2013 Author Share Posted December 15, 2013 Thank you. I used the stuff I mentioned, after cleaning the metal with acetone, and it's looking like it's going to work great. It really didn't even need the clamps to keep it in place. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted December 22, 2013 Author Share Posted December 22, 2013 Great. Little by little, hopefully I'm learning. Quote Link to comment Share on other sites More sharing options...
Riverman77 Posted December 24, 2013 Share Posted December 24, 2013 I used to lay formica (way back in the old days). Karin's idea sounds the best to me. Use a disposable 3" paint roller and paint on at least 2 coats of contact cement. Be sure to fully let each coat dry, of coarse. Slap 'em together and it will go no where. No screws or clamps needed either. Good luck. ~Riverman77 Quote Link to comment Share on other sites More sharing options...
