paulnptld Posted October 14, 2013 Share Posted October 14, 2013 After months of time in the shop, I got the Dolphin back and departed on a 2,000 mile road trip. Midway through I noticed that when the engine is under load, engine knock starts happening. This is especially noticeable when the transmission downshifts to 3rd. Any thoughts as to what might be causing this? Thanks! Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 14, 2013 Share Posted October 14, 2013 What type of engine? Sorry, just saw your 3.0 header. Pinging is usually caused by low octane fuel, wrong ignition timing, or incorrect heat range on your sparkplugs. I'm not familiar with that particular engine but I'm sure other members would have better info. Quote Link to comment Share on other sites More sharing options...
paulnptld Posted October 15, 2013 Author Share Posted October 15, 2013 I've been running with 87 octane, which seemed fine before all of the work was done on the engine. Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 15, 2013 Share Posted October 15, 2013 If the problem wasn't there before you had the work done I would bring it back and explain what its doing now. It could mean just a simple correction by the mechanic. Good Luck. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted October 18, 2013 Share Posted October 18, 2013 coming out of a shop, I would guess that is the source - timing is the first guess, followed by plugs, wires, vacuum lines etc, If you have a V6 you may have the ETC button - be curious if things get better with that engaged. Quote Link to comment Share on other sites More sharing options...
