soulshine73 Posted July 24, 2013 Share Posted July 24, 2013 i have a mid 70's 16 ft. camper with a 20r engine. alternator is not charging the battery so i can not drive at night. i figure i need a new alternator. will a regular 20r alternator work or do i need a special one because it is a camper? should i just rebuild the old one? thank you for any help/ comments in advance. Quote Link to comment Share on other sites More sharing options...
Maineah Posted July 24, 2013 Share Posted July 24, 2013 i have a mid 70's 16 ft. camper with a 20r engine. alternator is not charging the battery so i can not drive at night. i figure i need a new alternator. will a regular 20r alternator work or do i need a special one because it is a camper? should i just rebuild the old one? thank you for any help/ comments in advance. You'rs most likely has an external regulator it maybe worth your while to have some one check it out for you instead of replacing parts till it works. There is nothing special about the fact it is a MH same stuff as the pickup Quote Link to comment Share on other sites More sharing options...
soulshine73 Posted July 24, 2013 Author Share Posted July 24, 2013 where is the external regulator located? Quote Link to comment Share on other sites More sharing options...
5Toyota Posted July 25, 2013 Share Posted July 25, 2013 the xternal regulater is under the hood it should be on the driver side fender under the hoodmost often a squre black box with a plugin if there is a trustworthy rebuildre they can bench test the alternater to make shure. beware some of the places will tell you it is no good to sell you somthing i had that happen to me once Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted July 28, 2013 Share Posted July 28, 2013 most chain auto parts will test your alternator on or off your vehicle for free. Pretty sure it is a stock alternator - nothing special about it. Quote Link to comment Share on other sites More sharing options...
soulshine73 Posted July 29, 2013 Author Share Posted July 29, 2013 picked up an alternator from car quest for 36 dollars. seems to be working fine. thanks for all you help/info guys. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted July 30, 2013 Share Posted July 30, 2013 In case anyone cares still...later model 22Rs have easily rebuildable alternators. You just replace the brushes, which tend to be the only things that wear out. Under $20. But with the earlier engines like the 20R, the alternator is built differently and I couldn't find a good way to get at the brushes to replace them. I'll end up getting a rebuilt or new unit when mine starts failing. Quote Link to comment Share on other sites More sharing options...
