mini-wini-dan Posted June 25, 2013 Share Posted June 25, 2013 Hi Just doing some adjustments before I put my winnie on the road soon. When checking tires pressure I noticed the front tires were at 45 psi and the rear where 60 psi. It is inscribed right on the tires the maximum weight and psi is 50 on the front and 60 on the 4 rear tires. Any recommendations on tire pressure? Quote Link to comment Share on other sites More sharing options...
linda s Posted June 25, 2013 Share Posted June 25, 2013 Where is this inscription? certainly not on the tires. They have no front and rear max pressure tags. max pressure on the tires should be 65lb and I run mine 50 or 55 in front and 60 in the back. Linda S Quote Link to comment Share on other sites More sharing options...
waiter Posted June 25, 2013 Share Posted June 25, 2013 Tires have a "Inflate Max Pressure" marked on them., I think my Hankooks say 65psi.I run all 6 tires at about 60 psi. JOhn Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
mini-wini-dan Posted June 25, 2013 Author Share Posted June 25, 2013 Yes, I stand corrected when I returned to look at the inscriptions on the tires; my tires are Cooper-Discoverer on the front- load range C 8-ply 50 psi and weight limits are inscribed on the tires The rear duals are Cooper SRM II -load range D and weight limits and 65 psi inscribed on tires. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 25, 2013 Share Posted June 25, 2013 So your tires are telling you what pressure you can run. Max on front is 50 and rear is 65. I would run the front at max and the rear at 60 Linda S Quote Link to comment Share on other sites More sharing options...
mini-wini-dan Posted June 25, 2013 Author Share Posted June 25, 2013 Sounds like a good plan and my gas mileage will improve. Thanks for sharing your thoughts! Quote Link to comment Share on other sites More sharing options...
