snail powered Posted September 28, 2012 Share Posted September 28, 2012 T Quote Link to comment Share on other sites More sharing options...
waiter Posted September 28, 2012 Share Posted September 28, 2012 You mean like this? Window AC unit 1 Window AC unit 2 This unit works great, best test to date has been 95Deg with smoldering humidity. I made reflective window covers and the unit was able to keep it comfortable inside. I originally choose the smallest unit I could get. That way I could run it on a small generator and it fit perfectly in the cabinet. However, If I did it over again, I'd look around for a 7500 BTU. If you do this, you need to measure the inside of the cabinet (height, width, depth) and make sure it will fit this installation. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Maineah Posted September 28, 2012 Share Posted September 28, 2012 I think what you are talking about is a ductless A/C system. They are just starting to gain traction in the US. the compressor and condenser are remotely mounted and the evaporator is mounted inside as a small unit. Very compact units and yes they would work fine in a camper and are used in foreign MH's they make a lot of sense. We are starting to see them in houses in the US and some can accommodate up to 4 evaporator units. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 28, 2012 Share Posted September 28, 2012 Another alternative A/C (heat pump) not available here:- http://www.dometic.com/enie/International/Site/Caravan/AirConditioners-Ventilators/product/?productdataid=66886 Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted September 28, 2012 Share Posted September 28, 2012 i used waiter's plans and did it too. i agree with 5000 btu not being quite enough. when mine dies, and it will, i'll get the biggest that will fit and my gen will run. i also posted pictures of the installation. Quote Link to comment Share on other sites More sharing options...
BobBeery Posted September 30, 2012 Share Posted September 30, 2012 On size--our rooftop A/C is a 7000BTU. We haven't really been tested by horrible weather yet. We get between a 15 and 20 degree lower temp inside compared to out depending on how much direct sun we are parked in and how often we go out and come in. Quote Link to comment Share on other sites More sharing options...
