OBTOY Posted June 4, 2012 Share Posted June 4, 2012 Does anyone know the correct vents to buy from PPL for my 1984 Toyota Sunrader. Palm fronds damaged them. Thanks for the great information as usual. Deborah - OBTOY Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 4, 2012 Share Posted June 4, 2012 AFAIK, standard vents fit in a 14" square opening. The only exception that I'm aware of is that the holes used for Winnebago vents are 14" square but with rounded corners. Quote Link to comment Share on other sites More sharing options...
Davidadro Posted June 4, 2012 Share Posted June 4, 2012 Here's where I got mine for my Dolphin, but as Derek stated, standard 14x14 square vents are probibly what ya need. If all you need is the top part, just find out the make of your is vent first, as many use different lift mechinisms. Mine were Jensen (old style) for my 1983, and had no problem finding the cover for it here for my busted one, and a whole new complete aluminum replacement assembly here I bought for one beyond repair. As you stated, PPL, or one's local RV store would no doubt be able to help ya out too, but I find they can be more expensive, even after shipping is included. There are many options, and you should have no problem finding one, and the tops take very little effort and time to swap. Good luck and Peace! http://stores.ebay.c...d=p4634.c0.m322 Quote Link to comment Share on other sites More sharing options...
waiter Posted June 4, 2012 Share Posted June 4, 2012 Before buying a replacement vent top, visually inspect the entire vent to see if there are any problems. In particular, if the vent frame is plastic, it may be cracked (see link) and thus is a source for small leaks. Also the crank assembly, if there's any problems, opt to replace the entire vent. (New top is about $10, entire vent (with metal frame) is about $30 While your at it, look at all of them. If one is bad, the others are not far behind. Cracked vent frame Replacing roof vents John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted June 4, 2012 Share Posted June 4, 2012 i replaced three of the tops only. the way i determined if i was ordering the correct one was based on the hinge. sorry, can't remember where i found that info. there were three distinct hinge styles. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted June 5, 2012 Share Posted June 5, 2012 ISECOND THE METAL FRAME VINT IS THE ONLY WAY TO GO FOR A TOTAL REPLACMENT SOLVED MY LEAK ON MY PREVOUS MOTERHOME FINALY. Quote Link to comment Share on other sites More sharing options...
sweetleon Posted June 14, 2017 Share Posted June 14, 2017 I'm in a similar situation and need to install a new vent on my Sunrader. What would you use to seal around the new vent? Caulk? Putty? Tape? Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 14, 2017 Share Posted June 14, 2017 Butyl tape. Quote Link to comment Share on other sites More sharing options...
