Bigdog Posted May 17, 2012 Share Posted May 17, 2012 Trying to replace worn out bushings but can't get bolts and shackles out, nuts came off easy two different helpers have given up trying to force them out What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted May 17, 2012 Share Posted May 17, 2012 You're fighting rust, I'd guess. You're probably looking at using a torch or Sawzall to remove. Quote Link to comment Share on other sites More sharing options...
WME Posted May 18, 2012 Share Posted May 18, 2012 Have you removed the load on the rear shackles? You might try a pulley puller to push the bolt out. Quote Link to comment Share on other sites More sharing options...
