mickeypl Posted April 5, 2012 Share Posted April 5, 2012 (edited) Has anyone tired replacing the furnace thermostat on a sunrader? Mine is not very accurate. The coach is either hot or cold, it takes a while for thermostat to turn on and off! Another annoying thing with the sunrader is when the furnace fan starts its too noisy, after a few minutes it gets quiet. Has anyone experienced the same thing? Any suggestions? Edited April 5, 2012 by mickeypl Quote Link to comment Share on other sites More sharing options...
waiter Posted April 5, 2012 Share Posted April 5, 2012 I installed a digital thermostat on my Dolphin I think it was about $19 at the local Home Depot. My Furnace blower squealed when it first started and also when it stopped, I installed a new motor, About $100. http://toyotamotorhome.org/forums/index.php?showtopic=3520 John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 10, 2012 Author Share Posted April 10, 2012 So I ordered a new motor as well. Now I am wondering how to seal the propane gas connectors in the heater. Should I use Teflon?! it does get hot there so I am not sure! I installed a digital thermostat on my Dolphin I think it was about $19 at the local Home Depot. My Furnace blower squealed when it first started and also when it stopped, I installed a new motor, About $100. http://toyotamotorho...?showtopic=3520 John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted April 10, 2012 Share Posted April 10, 2012 What was used before to seal the gas connections? On most of these installations, brass flare fittings are used which don't require any teflon tape or goo or anything else for that matter, just the brass fitting itself. John Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 10, 2012 Author Share Posted April 10, 2012 John, There was nothing on two of them. One of them had some white stuff on it, very thin glue looking material, which made it very hard to unscrew. I think you are right, they don't require anything. Hopefully, they won't leak!? What was used before to seal the gas connections? On most of these installations, brass flare fittings are used which don't require any teflon tape or goo or anything else for that matter, just the brass fitting itself. John Quote Link to comment Share on other sites More sharing options...
waiter Posted April 10, 2012 Share Posted April 10, 2012 Where the copper tube screws onto the brass fittings should be flared and don't require sealant. Any pipe thread should use the white paste sealant. Just a small amount on the threads gives a good seal. Don't use the teflon tape, tiny strands can break off, and get inside valves and regulators. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
acudoc Posted April 12, 2012 Share Posted April 12, 2012 Brass flare fittings will leak if you use tape or sealer. Pipe fittings require tape etc. Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 17, 2012 Author Share Posted April 17, 2012 Thank for all the replies and good suggestion. So I went ahead and ordered the hydro-flame motor and replaced it. After putting everything together and re installing the unit on the coach, now I have an extra piece which I think goes on the outside door. The problem is under or over the door?! top or bottom? Some how I manged to forget this by the time I received the motor and replaced it. Please see the picture. Can someone help me here?<br /><br />Another question is whether I need to use sealer (in addition to putty tape) on the edges of the unit? if so what kind? Quote Link to comment Share on other sites More sharing options...
waiter Posted April 17, 2012 Share Posted April 17, 2012 Spare part!!! No idea. The only place you need sealant will be the outside where the intake and exhaust port is. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 17, 2012 Author Share Posted April 17, 2012 (edited) I am not clear about which intake and exhaust port you are talking about! Spare part!!! No idea. The only place you need sealant will be the outside where the intake and exhaust port is. John Mc 88 Dolphin 4 Auto Edited April 17, 2012 by mickeypl Quote Link to comment Share on other sites More sharing options...
waiter Posted April 17, 2012 Share Posted April 17, 2012 Look at the very first photo in the first post http://toyotamotorhome.org/forums/index.php?showtopic=3520 JOhn Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 17, 2012 Author Share Posted April 17, 2012 Mine has a different unit, which I think does not have the exhaust port, it might be built in the unit (hydroflame 8516). This unit bolts on from the outside and I put putty tape under the outside door. I am still wondering whether to add sealing on the outside edges or not! Look at the very first photo in the first post http://toyotamotorho...?showtopic=3520 JOhn Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted April 18, 2012 Share Posted April 18, 2012 the part looks like it would go above the door, acts like a gutter for water coming down the side. the putty tape should be all you need around the opening. Quote Link to comment Share on other sites More sharing options...
mickeypl Posted April 18, 2012 Author Share Posted April 18, 2012 I guess I will have to unscrew the top bolts and put it on top of the door. the part looks like it would go above the door, acts like a gutter for water coming down the side. the putty tape should be all you need around the opening. Quote Link to comment Share on other sites More sharing options...
