TR145 Posted March 11, 2007 Share Posted March 11, 2007 Hi, Our 1991 min Winnebago has a dead short? When the ground on the coach battery is hooked up the inverter relay clicks and then resets and then clicks. Pulled the fuses, still clicks, previous owner put a switch in the ground wire. It has a Magnetek 6300a inverter, Noted in the teck section they are not good. Will buy other unit but, would like to narrow it down to the inverter or something else before puting in the new unit. Thanks Trana Quote Link to comment Share on other sites More sharing options...
futar Posted March 17, 2007 Share Posted March 17, 2007 Ya, those old ones are terrible. I did the upgrade. It's easy and saves the battery. The old one can ruin the coach battery. It nearly ruined my cell phone. The upgrade is silent. The best price I found was here.. https://www.rvpartsoutlet.com/newstore/noja...D020706CF1BEE29 Good luck. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted March 20, 2007 Share Posted March 20, 2007 Sounds like the unit itself might be bad if you have the fuses pulled and it still resets. Do all the 12 volt dc electrical systems work with the 6300 turned off? Quote Link to comment Share on other sites More sharing options...
