vwbitts Posted February 4, 2011 Share Posted February 4, 2011 Does anyone know the dimensions for the u-bolt. I will be cutting mine off to install air bags and I will need replacements. Thanks! Quote Link to comment Share on other sites More sharing options...
bobby jo Posted February 5, 2011 Share Posted February 5, 2011 Does anyone know the dimensions for the u-bolt. I will be cutting mine off to install air bags and I will need replacements. Thanks! i just replaced mint to insall air bags and they are 9/16 Quote Link to comment Share on other sites More sharing options...
vwbitts Posted February 5, 2011 Author Share Posted February 5, 2011 thank you Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 6, 2011 Share Posted February 6, 2011 Also note that you buy them long and cut off the extra after your done. Here are some pics of the job http://toyotamotorhome.org/forums/index.php?app=gallery&module=user&user=1&do=view_album&album=207 The support system you see in m pics is not the recommended way to do things, sometimes you have to work with what you have. Be safe! Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 7, 2011 Share Posted February 7, 2011 A spring shop can make you a u bolt probably cheaper then you can buy it at a parts store take them the one you cut off. Greg is right they will be long that is normal in order to pull the spring pack together just cut off the excess. Quote Link to comment Share on other sites More sharing options...
vwbitts Posted February 7, 2011 Author Share Posted February 7, 2011 (edited) Ya, I was going to have a shop make them. Do you know the length and width of the bolt? Or, I guess, the specs, how to order, so I can get em ordered before taking off during the project?? Thanks! Edited February 7, 2011 by vwbitts Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 7, 2011 Share Posted February 7, 2011 Measure the plate holes or the center of the existing u bolt that is enough to let them know the radius of the bend. Quote Link to comment Share on other sites More sharing options...
vwbitts Posted February 8, 2011 Author Share Posted February 8, 2011 thanks Quote Link to comment Share on other sites More sharing options...
Totem Posted March 14, 2011 Share Posted March 14, 2011 thanks Hey there, any chance you have the U-bolt measurements for the 1 ton axle. my mech is replacing a 1/2 ton axle and I have no hardware to use as a template... -thanks in advance Quote Link to comment Share on other sites More sharing options...
