  • 1 month later...
Has anyone tried to upgade the 3.0L engine to a 3.4L? If so what is involved? Will the stock computer work? Is the auto tranny the same? Thanks
I never saw this done on a toyota motorhome, but I saw a Chevy 350 V* installed in 85 Toyota pickup truck
that had the 2.4 engine in it, and was actually a nice fit. There is a CA company that sells the needed motor
mounts and the transmission adaptor.
  • 7 months later...
This Swap looks to be an easy option!
You will need the ECU for the 5VZ-FE but most of the 3VZ stuff will/can go onto the 5VZ and it all bolts together!
The hard part is exhaust...
Lots of links available on this swap,
One of the closest I could find on a 1991 Two Wheel Drive X-cab....
http://www.automotivetalk.net/showmessages.php?id=633
Some more:
http://www.yotatech.com/showthread.php?t=69448
http://www.yotatech.com/showthread.php?t=82145
http://www.yotatech.com/showthread.php?t=50550
http://www.4x4wire.com/forums/showflat.php...part=1&vc=1
http://www.offroadsolutions.com/technicala...version_kit.htm
http://bb.bc4x4.com/showthread.php?t=21569...ight=5vzfe+swap
:rolleyes:
