Nard_ Posted April 7 Share Posted April 7 Hey everyone, I’m doing lots of small projects with my handy friends on my recent purchase of a Toy MH. Later this month my good friend who specializes in dry wall is going to help me install ceiling panels in my MH. He said maybe 1/4 plywood would do the trick but I was hoping to have something that’s smoother that would help it look nice and professional. Does anyone have suggestions for wood paneling for inside my MH? Links always help if you can provide one. thank you, N 1993 Toyota Warrior Quote Link to comment Share on other sites More sharing options...
MaineJed Posted April 7 Share Posted April 7 I used white plastic FRP sheets, flexible, durable and easy to clean. Quote Link to comment Share on other sites More sharing options...
Odyssey 4x4 Posted April 7 Share Posted April 7 Stay away from plywood, too heavy. You can use lauan board and put an frp panel over that. Quote Link to comment Share on other sites More sharing options...
Nard_ Posted April 7 Author Share Posted April 7 1 hour ago, Odyssey 4x4 said: Stay away from plywood, too heavy. You can use lauan board and put an frp panel over that. Ok awesome, I’ll be going to my local Home Depot to purchase Lauan board and frp paneling. Is there anything I can buy to put between 2 panels that meet so it looks flush? thank you, n Quote Link to comment Share on other sites More sharing options...
MaineJed Posted April 7 Share Posted April 7 Yes in the same isle as the FRP they should have a few different corners/ transitions that will work Quote Link to comment Share on other sites More sharing options...
linda s Posted April 7 Share Posted April 7 I think this would look classy. Used by itself the weight is less than the combined weight of luan and FRP. 7/32 in. x 48 in. x 96 in. White Nickel Gap Shiplap Panel WSP5548 - The Home Depot Linda S Quote Link to comment Share on other sites More sharing options...
Nard_ Posted April 7 Author Share Posted April 7 1 hour ago, linda s said: I think this would look classy. Used by itself the weight is less than the combined weight of luan and FRP. 7/32 in. x 48 in. x 96 in. White Nickel Gap Shiplap Panel WSP5548 - The Home Depot Linda S I like that! I might be sold on this. Is it relatively easy to remove cabinets in a toy MH? I’m looking to replace entire ceiling. Thank you, n Quote Link to comment Share on other sites More sharing options...
Nard_ Posted April 7 Author Share Posted April 7 What would work better for this project liquid nails or screws? Quote Link to comment Share on other sites More sharing options...
MaineJed Posted April 8 Share Posted April 8 I didn’t use Luan for the backside instead I put foam board and spray foam. Then FRP over it and screwed that to the studs etc. My goal was weight reduction and movement, these rigs get bounced around the road and from time to time I venture into the northern Maine woods on logging roads etc. Quote Link to comment Share on other sites More sharing options...
Grey Wolff Posted May 1 Share Posted May 1 Thanks for sharing, I need to replace the sides and front, inside forward due to unseen water leakage. It's just a matter of finding cardboard to make a template, then thanks to your info finding the correct material. Not looking forward to it, but I know in the end it'll add value to the RV. Mine is an 89 model with a fuel injected six cylinder with 85 thousand original miles. Quote Link to comment Share on other sites More sharing options...
Willie Alexander Posted Saturday at 02:23 PM Share Posted Saturday at 02:23 PM We used stained Luan to replace wall and ceiling panels. If you are on a budget, take the time to separate the panel from the insulation. Otherwise get some sheet foam and cut to fit. We used a pneumatic stapler to attach panels. Consider upgrading the cab over lighting whilst you have the panels off. On a 1989 Dolphin, at assembly it appears the roof was put on after the walls were finished. We used a quarter-round on the transitions to hide any mis-match. Cabinets come off pretty easily. Be sure to measure/mark/ identify where wiring penetrates panels. Take lots of pics! Quote Link to comment Share on other sites More sharing options...
