Nard_ Posted April 7 Share Posted April 7 (edited) Hey everyone! I noticed on our Toyota MH that when either connected to water with a hose or when the water pump is on we get some water coming out from a few places on the MH. We are taking a look at it some time next week but does anyone know what this might be? Just wanted to have a game plan when we start working on it with my friend who is a handy man. I also attached a video in case you wanted to take a look. thank you, N 1993 Toyota Warrior IMG_8494.mov Edited April 7 by Nard_ Mistake Quote Link to comment Share on other sites More sharing options...
extech Posted April 7 Share Posted April 7 you could be overpressurizing the system. a pressure regulator on the hose end will eliminate that as a possibility Quote Link to comment Share on other sites More sharing options...
Nard_ Posted April 7 Author Share Posted April 7 19 minutes ago, extech said: you could be overpressurizing the system. a pressure regulator on the hose end will eliminate that as a possibility it also seems to drip water underneath when not connected and just using water from the tank when the water pump is turned on. can you send a link for a pressure regulator? thank you, n Quote Link to comment Share on other sites More sharing options...
linda s Posted April 7 Share Posted April 7 Just using the water pump with water from the tank tells me pressure isn't the issue. You've just got a leaky pipe somewhere. Only you can find it Linda S Quote Link to comment Share on other sites More sharing options...
Nard_ Posted April 7 Author Share Posted April 7 7 hours ago, linda s said: Just using the water pump with water from the tank tells me pressure isn't the issue. You've just got a leaky pipe somewhere. Only you can find it Linda S Thank you Linda! Hopefully it’s an easy fix. Quote Link to comment Share on other sites More sharing options...
