HeroRyan Posted September 29, 2023 Share Posted September 29, 2023 Have a 1987 automatic sunrader and I heard one of the best performance mods to make overdrive useable is to put in 4.88 gearing into the rear differential. I've kept an eye on ebay, but haven't seen much come up. Anyone have any leads on where we could get a 4.88 third member? Are there alternate keywords that i can search which would fit our vehicles? Thanks Quote Link to comment Share on other sites More sharing options...
linda s Posted September 29, 2023 Share Posted September 29, 2023 1992 and up 4x4 truck or 4x4 4runner. The only one I could find with no ABS was the 92 pickup. Don't know if having abs complicates things. This is the site I use to find used parts. Car-Part.com--Used Auto Parts Market Linda S Quote Link to comment Share on other sites More sharing options...
JaySam Posted September 30, 2023 Share Posted September 30, 2023 I don't think ABS affects anything, I swapped in a 4.88 from a 94 4runner with abs and I just cut the wires at the sensor and had the shop put the gears in. I believe anything from 85-95 with work for the 3rd member but not positive about the year spread. Any pickup or 4 runner 3rd member should work. I found this page useful for locating a used 3rd member and making sure it would work https://lcengineering.com/toyota-4x4-gears-and-differentials/ There used to be a wonderful junkyard in Denver called the Yota Yard but unfortunately they have gone out of business. You might try calling LC Engineering and asking them where to source a used 3rd member, when I was at yota yard looking for one last year I called em up and they talked me through how to identify what I need on the spot. Very helpful guys. And the 4.88 upgrade made a world of difference, overdrive actually works!! Quote Link to comment Share on other sites More sharing options...
linda s Posted September 30, 2023 Share Posted September 30, 2023 The information I have shows no 4.88 differentials made until 1992. If you know a good mechanic you can just switch the gearing to 4.88. Lots of companies sell them. Linda S Quote Link to comment Share on other sites More sharing options...
