Buttfart Posted June 30, 2023 Share Posted June 30, 2023 having some issues with my 86 odyssey. My lights, fan, and outlets work when connected to shore power. The battery has over a 12v charge when tested. The system does not click or switch over to the battery when it isn’t running. The control panel and the 12v fridge never work even when plugged into shore power. There is no power when I check the fridge. Breakers and fuses in the box look fine to me. What am I missing? Thanks. Quote Link to comment Share on other sites More sharing options...
extech Posted June 30, 2023 Share Posted June 30, 2023 do the lights and stove vent fan work when not on shore power? Quote Link to comment Share on other sites More sharing options...
Buttfart Posted June 30, 2023 Author Share Posted June 30, 2023 Negative. Nothing works when not on shore power when driving or not driving Quote Link to comment Share on other sites More sharing options...
extech Posted June 30, 2023 Share Posted June 30, 2023 using a test light does it light up when checking the fuses? if no the switching relay may be corroded. it is inside the converter Quote Link to comment Share on other sites More sharing options...
