Iowacamper Posted March 4, 2009 Share Posted March 4, 2009 I take knobs off and see where the nuts are on control shafts...but how does the dash come apart?The panel under radio does not give access ether.How the hech does it come out?I am only getting AM and tape player works ok,just no FM. Quote Link to comment Share on other sites More sharing options...
sgtmike Posted March 4, 2009 Share Posted March 4, 2009 I've got a '91 Warrior and have been wondering the same darned thing. I got the knobs off and the shaft nuts off but how the heck do you get the radio to drop down..Can't get my hand up in there to do anything. So I'm interested in the same thing you are! SgtMike '91 Winnebago Warrior (AKA Ka Makoa) Quote Link to comment Share on other sites More sharing options...
motoyhomme Posted March 4, 2009 Share Posted March 4, 2009 Did you try taking the glove compartment out and going through there? Allen Quote Link to comment Share on other sites More sharing options...
Iowacamper Posted March 4, 2009 Author Share Posted March 4, 2009 ??? never thought about looking there,will check it out.This thing is harder to work on than my Goldwing,and they came from the same soil... Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 6, 2009 Share Posted March 6, 2009 Your title said you have a 92 so here is the drill for a 92. The radio comes out the front, remove the knobs from the heater controls (they just pull off) then remove the panel that the control shafts come thru this a a little tricky if you have some thing like a dental pick that works great. You can bend a small hook in a piece of stiff wire, stick it in the slot for the controls turn it so it catches behind and pull the heater panel out. Behind it there are two screws remove them and then pull the big trim piece off (it snaps in) If the radio is stock it is held in with screws. If you are going to replace it most radio shops sell adapters that just plugs into your wiring it will have to be wired to your new radio but the best part is you don't have to cut your motor home wiring. Quote Link to comment Share on other sites More sharing options...
Iowacamper Posted March 6, 2009 Author Share Posted March 6, 2009 This may just be it!The glove box route was a deadend..64 degrees in N.E Iowa today was a good day to wrench.Thanks maineah Quote Link to comment Share on other sites More sharing options...
sgtmike Posted March 6, 2009 Share Posted March 6, 2009 Maineah -- Is the 92 you're talking about, the same as one for a '91? Thanks SgtMike Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 7, 2009 Share Posted March 7, 2009 Any of the newer body styles 90 up?. Quote Link to comment Share on other sites More sharing options...
Iowacamper Posted March 7, 2009 Author Share Posted March 7, 2009 I see this will not matter much,year wise.I ran my vin. and see mine is a 91 not a 92 like all paper work shows.Anyway I looked at my dash and it looks like the panel around radio covers a large area of the dash,is this correct.And how hard do you have to pull outward with a pick to get it to release from clips?Thanks for a reply. Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 7, 2009 Share Posted March 7, 2009 They are a bit snug but nothing you need a crow bar to get out. It's best if the cab it warm, little more flexable. Yeah the panel does cover quite a lot maybe 10X12". I don't remember when they changed the body style maybe it was 89. I have an after market cd player and a dual band ham radio in the dash on my 97 Tacoma so there is all kinds of room the stock radios take up a lot of space. Quote Link to comment Share on other sites More sharing options...
