tropicstar Posted May 5, 2022 Share Posted May 5, 2022 Are the Nissan and Toyota 6 lug 1 ton full floating dual rear axle interchangeable? is there a difference between the Toyota and the Nissan 6lug full floating dual rear axles? Quote Link to comment Share on other sites More sharing options...
linda s Posted May 5, 2022 Share Posted May 5, 2022 No they are not interchangeable. They are built very similar though. Linda S Quote Link to comment Share on other sites More sharing options...
linda s Posted May 5, 2022 Share Posted May 5, 2022 Let me clarify that a bit.you would have to use a Nissan differential. You would need to have a pinion adapter to connect driveshaft to differential. You need Nissan dually wheels, different lug pattern than Toyota. No options for reverse dually in the front. The only plus is a 9 1/2 inch diff. Bigger than a Ford 9 inch Linda S Quote Link to comment Share on other sites More sharing options...
