International Posted October 29, 2021 Share Posted October 29, 2021 I recently bought a 1985 Toyota Dolphin. Using it semi-off grid until I feel comfortable boondocking. When I first started using the freshwater tank, it would easily last a week. Now it empties only after two days. I only use it for dishes and brushing teeth. Not sure where to start with identifying the where the leak is coming from. Any suggestions? Quote Link to comment Share on other sites More sharing options...
linda s Posted October 30, 2021 Share Posted October 30, 2021 Do you only turn the pump on hen your suing water? If not start doing that. Once the lines are pressurized the pipes can be leaking anywhere. Most likely near the pump or the water heater. Only way to find out is to dig in and search for water where it doesn't belong Linda S Quote Link to comment Share on other sites More sharing options...
International Posted November 2, 2021 Author Share Posted November 2, 2021 Thankfully not near the pump. Not sure if it has a water heater. Turns out there’s a tear in the hose that leads to the tank. Are those straightforward to replace? Quote Link to comment Share on other sites More sharing options...
