ka6uup Posted October 18, 2021 Share Posted October 18, 2021 I have a 1990 toyote rv with the 3vz-e v6 engine with 87k miles. I have the toyota owners manual but it doesn't specify theĀ mileage. Or at least I cant find it. Can anyone help. Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
Ctgriffi Posted October 18, 2021 Share Posted October 18, 2021 Here's Maintenance Schedule A, which is what you should probably use for these overloaded little trucks... 90-toyota-pickup-maint-sched-a.pdf Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 18, 2021 Share Posted October 18, 2021 Well hard question. It most likely was 3K but since then oils have improved quite a lot and now it's more like 5K. So here is the question how far do you think you will drive in a motor home during that range? Many oils at this point actually need to be driven to do the job they were intended to do. Sure hauling around a MH is pretty hard work so that is a factor. I'll still go with the 5K range I tow a camper with a Tacoma so I'm some where in the 6,000# range with the setup. So every two years. Quote Link to comment Share on other sites More sharing options...
