JIMER Posted July 19, 2021 Share Posted July 19, 2021 85 Dolphin, sr22. Anyone know at what temp. should the transmission fluid be to check both the cold band/circle AND the hot band/circle? Or where I can look it up online? Thanks, Jim Quote Link to comment Share on other sites More sharing options...
JIMER Posted July 19, 2021 Author Share Posted July 19, 2021 I see my friend Hunter asked the same question for me earlier today. I asked him first and he turned me onto this site. I'm a new to this forum and excited to find it. So we both would like to know, my research says if tested out of the the recommended fluid min. temp. it can actually be over filled and cause problems. My research also says that recommended temps are different makes, models and years. Any help will be greatly appreciated. Thanks, Jim. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 19, 2021 Share Posted July 19, 2021 This is from a guy I trust (a) Park the vehicle on a level surface. (b) Start engine when cold and let idle 5 minutes. With the parking brake applied, shift the selector into all positions from ”P” to ”L”, and then shift into ”P”. (c) Pull out the dipstick and wipe off the fluid with a clean rag. Re–insert the dipstick and pull out again. Check that the fluid level is in between the COLD and HOT ranges. Linda S Quote Link to comment Share on other sites More sharing options...
extech Posted July 19, 2021 Share Posted July 19, 2021 that is absolutely correct Quote Link to comment Share on other sites More sharing options...
