Mikeudsh Posted March 11, 2021 Share Posted March 11, 2021 I need some help friends. Have this old camper we are rebuilding. I need to figure out a few things -best a/c unit that runs off generator? - best refrigerator? -bench that folds into a bed? thanks so much for any help Quote Link to comment Share on other sites More sharing options...
WME Posted March 11, 2021 Share Posted March 11, 2021 So what came first the chicken or the egg? Generators and A/C units are sorta the same thing. Do you have a generator? If you do how many watts? A "normal" 13,500 BTU RV AC needs a 3500w generator. If no generator then you have a chance to match everything and get a more efficient setup. Here is a sorta package, your budget and quality wants may vari. Harbor Freight 2000w inverter generator (13 amps max) $550.00. Honda and Yamaha have 2200w and cost 2x$ https://www.harborfreight.com/engines-generators/gasoline-generators/2000-watt-super-quiet-inverter-generator-62523.html Coleman Mach 1 Power saver AC. 11,000 btu, 10 amps running $800.00. https://www.rvupgradestore.com/Coleman-Mach-Mach-I-PowerSaver-RV-AC-11-000-BTU-p/08-0055.htm You may still need an soft start kit. https://www.microair.net/products/easystart-364-3-ton-single-phase-soft-starter-for-air-conditioners?variant=30176048267 The refer is easy just get the biggest one that will fit, normally 3.7-4 cubic ft. You need a 2 way 110v/propane. A 110v/propane/12vdc is nice but not necessary. https://www.pplmotorhomes.com/parts/rv-appliances/rv-refrigerators-freezers/rv-refrigerators-and-freezers/refrigerators-dometic-americana_RM2451 Your looking for a jackknife sofa...https://www.amazon.com/jackknife-sofa-rv/s?k=jackknife+sofa+rv Quote Link to comment Share on other sites More sharing options...
Cynxing Posted March 11, 2021 Share Posted March 11, 2021 11 hours ago, Mikeudsh said: I need some help friends. Have this old camper we are rebuilding. I need to figure out a few things -best a/c unit that runs off generator? - best refrigerator? -bench that folds into a bed? thanks so much for any help Got a retro jacknife bench for sale that is 1/3 of the price of a new one. Plus 2 matching barrel chairs. Available immediately. Quote Link to comment Share on other sites More sharing options...
