abbiemax Posted March 8, 2020 Share Posted March 8, 2020 Rubber cover all bent up and no longer stays on, can't seem to find replacement, any suggestions? Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 8, 2020 Share Posted March 8, 2020 27 minutes ago, abbiemax said: rubber cover all bent up and no longer stays on, can't seem to find replacement, any suggestions? The cover at the bottom? Quote Link to comment Share on other sites More sharing options...
linda s Posted March 8, 2020 Share Posted March 8, 2020 If it looks like this it's still available from Toyota https://www.toyotapartsdeal.com/oem/toyota~seal~flywheel~housing~under~cover~dust~11366-65010.html?Make=Toyota&Model=Pickup&Year=1991&Submodel=2+Wheel+Drive&Filter=()&Location=engine_fuel_tool/timing_gear_cover_rear_end_plate,,11366 If it looks like this a junk yard is your only option https://www.toyotapartsdeal.com/oem/toyota~cover~flywheel~housing~under~11361-65010.html?Make=Toyota&Model=Pickup&Year=1991&Submodel=2+Wheel+Drive&Filter=()&Location=engine_fuel_tool/timing_gear_cover_rear_end_plate,,11361 I'm assuming you have a V6 because I can find no similar parts for the earlier trucks Linda S Quote Link to comment Share on other sites More sharing options...
abbiemax Posted March 9, 2020 Author Share Posted March 9, 2020 looks like the junkyard option, 4cyl to a43d, is this cover necessary? prob.never find at junkyard, will have to try to fab something I guess Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 9, 2020 Share Posted March 9, 2020 50 minutes ago, abbiemax said: prob.never find at junkyard ... Certainly not near me. In the Rust-belt' they were all crushed years ago. Where are you located? Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 9, 2020 Share Posted March 9, 2020 It is a cover to access the converter bolts is it necessary? Not really but if you could find one it would not hurt. Quote Link to comment Share on other sites More sharing options...
