DanielM Posted June 10, 2019 Share Posted June 10, 2019 Hi All, so I've found a couple threads about replacing different parts of the lighting assembly that's next to the door to the coach on our 1987 Dolphin. I've got a new lens cover and switch ordered because it was rusted out, but what I can't figure out is where to buy a replacement light socket that will fit into the assembly. Is this just a general sized light socket of some kind?? Any help would be much appreciated... Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 10, 2019 Share Posted June 10, 2019 I think a trip down to your local parts store will get you a bulb socket. It even doesn't have to be for the same bulb as the original. Pick up a matching LED bulb while there. Some fabrication might be needed to install. Quote Link to comment Share on other sites More sharing options...
DanielM Posted June 10, 2019 Author Share Posted June 10, 2019 3 minutes ago, Derek up North said: I think a trip down to your local parts store will get you a bulb socket. It even doesn't have to be for the same bulb as the original. Pick up a matching LED bulb while there. Some fabrication might be needed to install. Great, thanks Derek. That's what I'll do! Quote Link to comment Share on other sites More sharing options...
linda s Posted June 11, 2019 Share Posted June 11, 2019 Bulbs are almost the same as my Explorer, just different intensity. Auto socket would work perfect and since it's already for a 12 volt light easy match. NAPA? Linda S Quote Link to comment Share on other sites More sharing options...
Caribemj Posted July 5, 2019 Share Posted July 5, 2019 On 6/10/2019 at 4:12 PM, DanielM said: Hi All, so I've found a couple threads about replacing different parts of the lighting assembly that's next to the door to the coach on our 1987 Dolphin. I've got a new lens cover and switch ordered because it was rusted out, but what I can't figure out is where to buy a replacement light socket that will fit into the assembly. Is this just a general sized light socket of some kind?? Any help would be much appreciated... Can you tell me/us where you got the switch? I’m at the same point of repair! Also, did you figure out the bulb issue? Thanks! Quote Link to comment Share on other sites More sharing options...
DanielM Posted July 5, 2019 Author Share Posted July 5, 2019 (edited) Hi Caribemj, Mine actually had a toggle switch rather than that pop style that you have, and I found the exact same switch as mine at Napa auto parts, and ended up just buying a small bulb socket that was for a taillight. The bulb doesn’t clip into the fixture like it originally did, but it does the job. I was unsuccessful are Auto Zone and advanced auto parts, but Napa had a good selection. I am a bit confused by your picture though, it seems that your light and switch are behind the rear plate of the fixture?? Edited July 5, 2019 by DanielM Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted July 7, 2019 Share Posted July 7, 2019 Hey! Linda posted a link to buy a New old stock Bargman grab handle with the new lens cover! Perfect! All the Lens covers fit this. I installed mine just before I sold Grannie. Quote Link to comment Share on other sites More sharing options...
