darren. Posted May 29, 2018 Share Posted May 29, 2018 I need to replace my front brake pads, but I can't figure out which ones to buy. RV is a 1992 Toyota Horizon. V6. 3 liter. Quote Link to comment Share on other sites More sharing options...
linda s Posted May 29, 2018 Share Posted May 29, 2018 Go to rockauto.com and do the drill down. Go to Toyota, your year, pickup ,then brakes and front pads. There are many to choose from and the ones correct for your truck say double rear wheel. I avoid Centric because I have had issues in the past with their products. Or you can just go to a Toyota dealer. Toyota still makes them. It will just cost a lot more Linda S Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted May 29, 2018 Share Posted May 29, 2018 (edited) there is a thread just above yours (later). You just need to get the dual rear wheels /cab & chassis etc...listings..... attached is a pdf showing current rock auto listings. I got the ones in the pics years ago for $6.13. Note pdf link at bottom rockbrake.pdf Edited May 29, 2018 by DanAatTheCape Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 29, 2018 Share Posted May 29, 2018 There are two, the parts stores often have problems with that yours are 1 ton brakes the rotors are bigger and the pads are different. Quote Link to comment Share on other sites More sharing options...
darren. Posted June 1, 2018 Author Share Posted June 1, 2018 So I need 1 ton brakes with Dual Rears? Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 2, 2018 Share Posted June 2, 2018 some thing like that - depends on the parts store listings.... When you get them off you can measure them - take them in with you to the store. You will find out what stores have employees that know there stuff .... Quote Link to comment Share on other sites More sharing options...
linda s Posted June 2, 2018 Share Posted June 2, 2018 If your location is still correct I found the right pads at Napa and there is one near you. They might have to order it but you could give them a call https://www.napaonline.com/en/p/PFZPF7321M Oh and they also carry premium ones. I would go with the better quality https://www.napaonline.com/en/p/RSSSS7321M Linda S Quote Link to comment Share on other sites More sharing options...
