WME Posted September 8, 2017 Share Posted September 8, 2017 "Winter is coming, you must prepare" Battery maintainers for 1,2 or 4 batteries http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Smart-Trickle-Charger-and-Battery-Maintainers/3994744/10002/-1?utm_campaign=20170907email&utm_medium=email&utm_source=email Quote Link to comment Share on other sites More sharing options...
Homer Posted September 12, 2017 Share Posted September 12, 2017 I use this and have for 8 yrs and still using my deep cycle battery for the coach. When I come home I plug it up to it and it stays on there plugged up until We go and then I unplug it. Usually lasts a week or more using it dry camping. NorthernTool.com 1-800-221-0516 Call Your Local Store To Confirm Availability FREE SHIPPING — BatteryMINDer Plus Charger/Maintainer/Desulfator — 1.3 Amp, 12 Volt, Model# 12117 Item# 167981 Overall Rating: 4.8 / 5 <div class="BVRRRatingsHistogramButtonImage"><a name="BV_TrackingTag_Rating_Summary_1_ExpandHistogram_167981" href="http://reviews.northerntool.com/0394/167981/ratingsnapshot.htm" target="_blank"> <img src="http://northerntool.ugc.bazaarvoice.com/static/0394/openRatingsHistogram.gif" alt="Open Ratings Snapshot" />& lt;/a></div> 806 Reviews : 167981 Click image to enlarge Was $49.99 Sale $29.99 Save $20.00 + Free Shipping (Lower 48 states) Was $49.99 Advantage $24.99 Save $25.00 + Free Shipping (Lower 48 states) Qty Add to Cart Item in Cart Save ForLater Item Saved Full-time battery monitoring automatically tests battery every microsecond, supplying only the current needed to maintain battery at full charge 2-stage unit charges and maintains from 1 to 4 batteries at a time (12V batteries parallel-connected or 6V batteries series-connected. NOTE: Never connect 2 or more batteries together in parallel before fully charging each and checking their condition. Failure to fully charge each battery and check their condition can result in a serious safety hazard) Does not overcharge, regardless of time connected High-frequency pulses safely remove sulfate from battery's plates that prevent the batteries from holding a full charge No need to add water to maintenance-type batteries during long, non-use storage See full description Quote Link to comment Share on other sites More sharing options...
