KGordon Posted July 7, 2017 Share Posted July 7, 2017 Another newbie question. The exterior cover for my fresh water tank is pretty chewed up, and I'm not sure how it opens. Before I start prying with a screwdriver and possibly damage it irreparably, can someone tell me how it opens. I have a feeling it will need to be replaced. Quote Link to comment Share on other sites More sharing options...
linda s Posted July 7, 2017 Share Posted July 7, 2017 The center round part pulls out. There should be a little loop pull with a section that goes down to the non moving part to lock it. Not much room to lock it though. I use a wire bag twist thing from the grocery store. Should also be an O-ring to seal it right there when you open it. Buy a new one. Oops. I thought I would find them everywhere and give you a link. I only found them one place but here goes. You can also see better how it works from the pics. Most of the newer ones would require you to cut a bigger opening in your motorhome. Yuck. Just replace it before they disappear completely. Linda S http://www.dyersonline.com/valterra-telescoping-water-fill.html Quote Link to comment Share on other sites More sharing options...
Nam Posted July 9, 2017 Share Posted July 9, 2017 That one would be very helpful Linda in places where the campground does not allow hose hook up to the RV. I had to cut a water bottle to do the same. I now carry a battery powered pump. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted July 9, 2017 Share Posted July 9, 2017 6 hours ago, Nam said: That one would be very helpful Linda in places where the campground does not allow hose hook up to the RV. I had to cut a water bottle to do the same. I now carry a battery powered pump. Another new one. A campground that does not allow hose hook up? Cannot say I have found one of those yet. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted July 9, 2017 Share Posted July 9, 2017 I have used a plastic bottle with an opening cut in one side to fill water when I could not get close enough to a faucet - so I used gallon jugs and the little bottle as a funnel. A heavier plastic than the one shown. Quote Link to comment Share on other sites More sharing options...
KGordon Posted July 13, 2017 Author Share Posted July 13, 2017 Thanks for the great info! Will definitely follow up. Quote Link to comment Share on other sites More sharing options...
sweetleon Posted July 13, 2017 Share Posted July 13, 2017 I installed this one from Amazon on my Sunrader: http://a.co/6QmYlux Quote Link to comment Share on other sites More sharing options...
