AzRetired
EU2200 Honda Generator
Will an EU2200 Honda Generator will run a factory air conditioner unit on a Dolphin Motor Home?
Yes most likely, a 2000 is iffy. That being said it does not leave a lot of room to run other high demand things like toasters and microwaves.
Thank you Maineah.
I have that same model of Honda generator.  This newer EU2200i has a little more output than the older EU2000i.
It will not start my Carrier 13.5kbtu AC unit by itself but with the Micro-Air easy start add-on I'm able to start and run the AC unit.
There is a little more discussion on this topic here:
Thank you AtlantaCamper!
There is much confusion on this subject.   Earlier Toy homes may have been fitted with a 7000 or 8000 btu roof air.  A 2000 watt generator will run them with ease.
My Honda 2000 will not start my 11000 btu roof air without a hard start capacitor.  With a hard start it will not start and run the 11k unit dependably in hot weather.
So first you need to know how many btu your roof air is.
Thank you jjrbus!
A 2000 watt generator and a hard start cap "may" work depending on the AC unit. But if you are going to buy a generator go big or go home! Ideally a Honda 3K will run everything but they are big. The 2200 is doable Yamaha makes a 2400 watt portable unit it would be my choice if I need AC because it would run other things at the same time like battery chargers etc. no problem. It's not light (75#)  and it's close to Honda's 2200 price. My old Nova Star had a Onan built in it ran everything it was 2400 watts.
My Honda 2000i runs my Dometic 11k unit without problems but cannot run anything else.
